1989 Nissan 240SX Fuel Injector Cleaning
MBRUCE84
  • 6 POSTS
1989 Nissan 240SX 212,000 miles(yeah, she's still going): I've come to the conclusion that my fuel injectors either need to be replaced or cleaned. Since it's so expensive to replace all the injectors [b:6d4a6b3216]is there any way to clean them yourself in a cost effective way?[/b:6d4a6b3216]
Mar 7, 2006 at 1:36 PM
FISHERMAN
  • 937 POSTS
Get them to a shop where they can bench-clean them. Be sure to replace the rubber o-rings.
its cheaper that way than try to do it yourself, they use ultrasonic and pressured chemicals.
loock around for a shop capable of doing that and compare prices, here at Los Angeles area charge around 10 dollars a piece.
Mar 7, 2006 at 2:11 PM
Suggested Repair
Have the fuel injectors professionally bench-cleaned with ultrasonic cleaning and pressurized chemicals, and replace the rubber o-rings. Compare local shop prices; professional cleaning is typically cheaper than DIY cleaning or replacing all injectors.
Conversation Summary
The owner of a 1989 Nissan 240SX with 212,000 miles asked whether fuel injectors can be cleaned cost-effectively at home instead of replaced. The expert recommended taking them to a shop for bench cleaning with ultrasonic and pressurized chemicals, replacing the rubber o-rings, and comparing prices, noting some shops charge about $10 per injector.
