i have a 1989 nissan 240sx and the fuel gauge does not work the needle is all the way down its nt even on the E wat could be wrong with it
Oct 16, 2007 at 2:28 PM
Check the back of the dashboard for a loose connector or wire. If those are fine, drop the gas tank and inspect the fuel-level sender (potentiometer) and its connector.
The owner of a 1989 Nissan 240SX reports the fuel gauge needle stays all the way down, below E. The expert advises checking the dashboard rear for a loose connector or wire, then dropping the tank to inspect the fuel-level sender unit or its connector if the dash wiring is good.
