There are many possible causes for the non starting and here are some diagnostic procedures.
WILL NOT START
NO COMBUSTION ( cranks without any fifing)
Monitor vehicle's tachometer while cranking engine (at least 250 RPM).
2. Check fuel pump operation.
3. Perform appropriate INJECTOR MALFUNCTION diagnostic.
4. Connect inductive timing light to spark plug wire and check for weakness in flash.
5. Ensure spark plug wires are within allowable resistance values.
6. Check for spark using spark tester.
7. For Code 11: Enter self -diagnostic Mode III and retrieve codes. If vehicle will not start, crank engine before entering self -diagnostic Mode III.
For Starter Signal: Enter self -diagnostic Mode IV and perform appropriate switch tests.
For Coolant Temp & Crank Angle Sensor: Enter self -diagnostic Mode III and retrieve
If Equipped: Perform AIR REGULATOR diagnostic
SPONSORED LINKS
Monday, September 14th, 2009 AT 8:11 AM
