Hi LarryLL2,
Thank you for the donation.
Symptoms indicates a major power supply line is faulty.
Did you check the fusible links?
Did you use a test lamp or volt meter to test the fuses for power supply?
Check for loosened connectors between battery and interior.
SPONSORED LINKS
Friday, July 23rd, 2010 AT 12:53 PM
