Hi Nathan,
Here are some thing to check.
Check for Spark at the Plugs. Should be Bright Bluish/White. If no spark check for spark at coil if still no spark check for power to coil.
Check Cap and Rotor for Build up on contacts, if has build up clean and see if will start. If starts replace cap and rotor.
Check fuel pump - can you hear a buzz coming from the gas tank area that lasts for 2 - 3 seconds. If so check fuel pressure also check for clogged fuel filter(when was last filter change?).
Post findings.
SPONSORED LINKS
Tuesday, April 21st, 2009 AT 12:26 PM
