New front calipers
119,000 MILES • 5.2L • V8 • 4WD • AUTOMATIC
ROBERT HALL2
Changed everything brake wise front and rear. New calipers leak at seal point of banjo bolts. Calipers came with two crush washers, copper type. Do they require both of them? Plus they came with this bent up wire thing. No clue where it goes. they did not have them when I started. I am disabled and cannot afford a mechanic or someone else would be throwing things instead of me.
Dec 7, 2016 at 2:45 AM
HMAC300
  • 48,601 POSTS
yes they require one washer on each side that is why it is leaking more than likely there are three different types of calipers. send a picture back of the ones on truck.
Dec 7, 2016 at 4:23 AM
STEVE W.
  • 15,413 POSTS
Copper washer on each side of the banjo fitting. The bent up wire it the anti-rattle spring. Goes on the inner pad with the loop side away from the rotor.
Dec 7, 2016 at 2:10 PM
