Brake caliper bolts
140,000 MILES • 4.7L • V8 • 2WD • AUTOMATIC
RACHEL DOWNING
  • 5 POSTS
Is there a drastic size difference between a brake caliper bolt kit that says:
Notes: Front null
Item Grade: Standard Replacement
Kit Contents: Caliper Guide Pin Bolts
Vs.
Notes: Disc brake caliper bolt kit. Front. Oversize.
Package Contents: 1 Caliper Bolt
Apr 9, 2017 at 6:37 PM
STEVE W.
  • 15,419 POSTS
The over-sized ones are used if you strip the threads in the caliper mount (fairly common problem). If the standard ones still have good threads you do not need the larger ones. But they do allow you to get the vehicle back together faster.
I do not like the over-sized ones myself because as they cut new threads as you install them, which means it is possible to get them threaded crooked. My SOP in the case of stripped threads is to install a thread insert (9mmX1.25). That allows you to use the factory size and the threads are now stronger than the factory threads as well.
Apr 9, 2017 at 7:41 PM
RACHEL DOWNING
  • 5 POSTS
Thank you so much. That is exactly what I needed to hear. =)
Apr 9, 2017 at 7:52 PM
  • 55,770 POSTS
Steve W. is the best mechanic on the site!
, Ken
Apr 12, 2017 at 11:42 AM
