New AC compressor clutch out
CANNON1349
  • 672 POSTS
Shims behind the nut or the clutch? I don't have a clutch puller tool. And I just did a quick search and I don't think Advance sells shims for A/C compressors.
Thursday, September 12th, 2019 AT 4:16 AM
  • 52,797 POSTS
Once you remove the nut, the clutch comes off without a puller.
In your situation, you would need to remove shims, not add them.
Thursday, September 12th, 2019 AT 4:23 AM
CANNON1349
  • 672 POSTS
Okay, so is the air gap the lip between the clutch and pulley? Or somewhere else? And is it.017 inches or mm?
Thursday, September 12th, 2019 AT 4:25 AM
  • 52,797 POSTS
Between the clutch plate and the pulley.
>017 inches. I do not do mm.
Thursday, September 12th, 2019 AT 4:28 AM
CANNON1349
  • 672 POSTS
Okay. I will pick up a set of feeler gauges and try this later this evening.
Thursday, September 12th, 2019 AT 4:29 AM
  • 52,797 POSTS
Sounds like a plan.
Thursday, September 12th, 2019 AT 4:31 AM
CANNON1349
  • 672 POSTS
Is there a torque spec for that nut?
Thursday, September 12th, 2019 AT 4:40 AM
  • 52,797 POSTS
18 ft. Lbs.
Thursday, September 12th, 2019 AT 4:41 AM
CANNON1349
  • 672 POSTS
Well the feeler gauge shows the air gap at.021"
But none of my sockets get to that nut in there, how do you get to it?
Thursday, September 12th, 2019 AT 4:16 PM
  • 52,797 POSTS
You need a deep 6 point socket that is thin walled.
Thursday, September 12th, 2019 AT 4:39 PM
CANNON1349
  • 672 POSTS
Is it 15mm? I have deep sockets but specifically thin walled I don't know where to get
Thursday, September 12th, 2019 AT 4:43 PM
  • 52,797 POSTS
Chrome sockets are thin sockets.
I believe it is either a 14 or 15 mm nut.
Friday, September 13th, 2019 AT 3:42 AM
CANNON1349
  • 672 POSTS
Nuts off. Clutch wont budge. I have 2 and 3 jaw pullers and they can't get a grip.
Friday, September 13th, 2019 AT 5:08 PM
  • 52,797 POSTS
Is the inside of the clutch threaded?
Friday, September 13th, 2019 AT 5:53 PM
CANNON1349
  • 672 POSTS
Looks like it.
Friday, September 13th, 2019 AT 6:07 PM
  • 52,797 POSTS
Okay, nuts. That is one that is pressed on. It does not show it in my data.
There is a puller that screws into the clutch and pushes it off.
https://www.amazon.com/CTA-Tools-7500-Remover-Installer/dp/B009VI9UBW/ref=sr_1_18?keywords=gm+air+conditioner+clutch+puller&qid=1568424075&s=gateway&sr=8-18
Friday, September 13th, 2019 AT 6:22 PM
CANNON1349
  • 672 POSTS
Okay, so got the clutch plate off with the tool. No spacers here. Pulley is held on with a snap ring I think.
Saturday, September 14th, 2019 AT 1:59 PM
CANNON1349
  • 672 POSTS
Never mind. Looks like I just gotta press the plate back on until it's in spec.
Saturday, September 14th, 2019 AT 3:37 PM
CANNON1349
  • 672 POSTS
So the scratching is definitely gone. But the compressor seems to go on/off at 2000 rpm. Is it supposed to do that? Can kind of feel it while driving, and doesn't affect the temperature
Saturday, September 14th, 2019 AT 4:38 PM
  • 52,797 POSTS
Kep me updated.
Saturday, September 14th, 2019 AT 4:40 PM
