New ac compressor clutch out
325,000 MILES • 4.3L • V6 • 2WD
CANNON1349
  • 861 POSTS
shims behind the nut or the clutch? I don't have a clutch puller tool. And I just did a quick search and I don't think Advance sells shims for A/C compressors.
Sep 11, 2019 at 9:16 PM
Once you remove the nut, the clutch comes off without a puller.
In your situation, you would need to remove shims, not add them.
Sep 11, 2019 at 9:23 PM
CANNON1349
  • 861 POSTS
Okay, so is the air gap the lip between the clutch and pulley? or somewhere else? And is it .017 inches or mm?
Sep 11, 2019 at 9:25 PM
Between the clutch plate and the pulley.
>017 inches. I do not do mm.
Sep 11, 2019 at 9:28 PM
CANNON1349
  • 861 POSTS
Okay. I will pick up a set of feeler gauges and try this later this evening.
Sep 11, 2019 at 9:29 PM
Sounds like a plan.
Sep 11, 2019 at 9:31 PM
CANNON1349
  • 861 POSTS
Is there a torque spec for that nut?
Sep 11, 2019 at 9:40 PM
18 ft. lbs.
Sep 11, 2019 at 9:41 PM
CANNON1349
  • 861 POSTS
Well the feeler gauge shows the air gap at .021"
But none of my sockets get to that nut in there, how do you get to it?
Sep 12, 2019 at 9:16 AM
You need a deep 6 point socket that is thin walled.
Sep 12, 2019 at 9:39 AM
CANNON1349
  • 861 POSTS
Is it 15mm? I have deep sockets but specifically thin walled I don't know where to get
Sep 12, 2019 at 9:43 AM
Chrome sockets are thin sockets.
I believe it is either a 14 or 15 mm nut.
Sep 12, 2019 at 8:42 PM
CANNON1349
  • 861 POSTS
Nuts off. Clutch wont budge. I have 2 and 3 jaw pullers and they can't get a grip.
Sep 13, 2019 at 10:08 AM
Is the inside of the clutch threaded?
Sep 13, 2019 at 10:53 AM
CANNON1349
  • 861 POSTS
Looks like it.
Sep 13, 2019 at 11:07 AM
Okay, nuts. That is one that is pressed on. It does not show it in my data.
There is a puller that screws into the clutch and pushes it off.
https://www.amazon.com/CTA-Tools-7500-Remover-Installer/dp/B009VI9UBW/ref=sr_1_18?keywords=gm+air+conditioner+clutch+puller&qid=1568424075&s=gateway&sr=8-18
Sep 13, 2019 at 11:22 AM
CANNON1349
  • 861 POSTS
Okay, so got the clutch plate off with the tool. No spacers here. Pulley is held on with a snap ring I think.
Sep 14, 2019 at 6:59 AM
CANNON1349
  • 861 POSTS
Never mind. looks like I just gotta press the plate back on until it's in spec.
Sep 14, 2019 at 8:37 AM
CANNON1349
  • 861 POSTS
So the scratching is definitely gone. But the compressor seems to go on/off at 2000 rpm. Is it supposed to do that? Can kind of feel it while driving, and doesn't affect the temperature
Sep 14, 2019 at 9:38 AM
Kep me updated.
Sep 14, 2019 at 9:40 AM
CANNON1349
  • 861 POSTS
Compressor turns on and off when over 2000 rpm. Can kind of feel it while driving. But no scratching like before. Low side 25 psi and high side 250
Sep 14, 2019 at 10:54 AM
Low side is low. At 2k does the low side drop off more.
Sep 14, 2019 at 11:12 AM
CANNON1349
  • 861 POSTS
I think it did just a hair, think it's a Freon problem?
Sep 14, 2019 at 11:18 AM
Yes. The low pressure switch shuts down the system when the low pressure hits 20 lbs.
That indicates a bad expansion valve.
Sep 14, 2019 at 4:27 PM
CANNON1349
  • 861 POSTS
can't be. The orifice tube and condenser are maybe a month old. I probably just measured it wrong.
Sep 14, 2019 at 11:30 PM
The gauge is accurate.
Yes, it can be. If the tube is defective or clogged, it will do this.
Take the readings again and post a picture of the gauges at 2k.
Sep 14, 2019 at 11:52 PM
CANNON1349
  • 861 POSTS
The pressure is also in the 20's before 2k.
Sep 14, 2019 at 11:54 PM
I know. You mentioned that already.
Sep 14, 2019 at 11:57 PM
