Turns over but will not start
2003 SUZUKI VITARA
98,000 MILES • 2.0L • 4 CYL • 2WD • AUTOMATIC
COREY CROWLEY
I am having issues starting my vehicle. the engine turns over, but I have no fuel or fire to the spark plugs. There is a new cam position sensor and battery in it. I have check every and all fuses and still have not found the problem. Is it the ECU gone bad? because I have power and my diagnostic tool connects to it and is not showing me the issue.
Aug 20, 2016 at 12:28 PM
KHLOW2008
  • 41,814 POSTS
Firing of spark plugs requires the crank sensor to be working. Have you checked it yet? Are you getting power supply to the ignition coils?
Aug 21, 2016 at 6:12 PM
COREY CROWLEY
Yes, I have diagnosed and checked it and I believe its the ECU because I have no fuel or fire. But it will turn over just not start.
Aug 21, 2016 at 6:14 PM
RENEE L
  • 1,260 POSTS
Hi Corey,
Here is a link to an informative article from this site with step by step instructions and pictures and a video on what to check for when your vehicle cranks, but will not start.
If you need any further help please come back to the site as we are always happy to help.
Thank you for visiting 2CarPros.
Kindest regards,
Renee
Admin
Aug 22, 2016 at 11:48 AM
