Multiple misfires after plugs and coil pack replacement?
JOSEPH.FOLWER
  • 19 POSTS
Okay, the codes did come back just do not them yet will update you tomorrow.
Tuesday, July 2nd, 2024 AT 12:26 PM
JOSEPH.FOLWER
  • 19 POSTS
No dark smoke just vibrates as I accelerate from 20 MPH to 60 then levels out.
Tuesday, July 2nd, 2024 AT 4:13 PM
  • 109,951 POSTS
Does the check engine light flash when you feel this? I ask because if there is a misfire, the CEL normally will flash. If it isn't, we may have something different happening.
Tuesday, July 2nd, 2024 AT 7:24 PM
JOSEPH.FOLWER
  • 19 POSTS
No, it does not, and it vibrates like a washing machine and runs rough even at 60 MPH. I agree it something else but what everything would present codes.
Tuesday, July 2nd, 2024 AT 7:35 PM
  • 109,951 POSTS
If you are getting a vibration when you accelerate, it could be related to a faulty CV joint, wheel bearing, and other components related.
Have you had a chance to make sure nothing is loose or damaged with the final drive portion of the vehicle?
Tuesday, July 2nd, 2024 AT 7:55 PM
JOSEPH.FOLWER
  • 19 POSTS
Good morning,
I did do all those things yesterday I jacked up and I do have cv joint wear but my main thing is I think it might be still be electrical and maybe vacuum issues and do you have hose diagram.
Wednesday, July 3rd, 2024 AT 5:42 AM
  • 109,951 POSTS
I checked both of my manuals, and for some reason, there are no vacuum schematic listings. Is there anything under the hood that shows the vacuum system?
Wednesday, July 3rd, 2024 AT 8:29 PM
JOSEPH.FOLWER
  • 19 POSTS
Yes, it is vague at best. I also have a code for the catalytic converter I was going to change that this weekend.
Friday, July 5th, 2024 AT 6:25 AM
  • 109,951 POSTS
Since you are questioning the catalytic converter, take a look through this link first and see i anything mirrors what you are experiencing:
https://www.2carpros.com/articles/bad-catalytic-converter-symptoms
If you feel it does, here is a link that explains how to test it:
https://www.2carpros.com/articles/how-to-test-a-catalytic-converter
Saturday, July 6th, 2024 AT 9:24 PM
