1999 Mitsubishi Eclipse Sputter
MITSUBISHI
KBEUCKE
  • 78 POSTS
I have a 1999 Eclipse non-turbo. When I accelerate I get a sputter and lack of power. I thought it could be the fuel filter so I replaced that. It is still doing it. Could you provide a little direction on what I should check from here?
Sep 28, 2007 at 4:35 AM
2CARPRO JACK
  • 11,533 POSTS
Start with ignition....has it been tuned up recently? New plugs, wires (if applicable). Might even be an ignition coil breaking down, but take care of the basics first
Sep 28, 2007 at 5:50 AM
KBEUCKE
  • 78 POSTS
Thanks for the help. When looking for the coil I see the spark plug wires hook directly to it. Do I not have a distributor on this car? If not how does this work? Do a lot of the newer cars not have distributors?
[quote:a0b0d011d6="2CarPro Jack"]Start with ignition....has it been tuned up recently? New plugs, wires (if applicable). Might even be an ignition coil breaking down, but take care of the basics first[/quote:a0b0d011d6]
Sep 29, 2007 at 4:22 AM
2CARPRO JACK
  • 11,533 POSTS
Yes, it is quite common for there not to be a distributor.The PCM sees the engine turning via the cam and crank angle sensors and fires the coil at the appropriate times
Sep 30, 2007 at 1:03 AM
Suggested Repair
Start with a basic ignition tune-up: inspect and replace spark plugs and plug wires if due. If the sputter continues, check the ignition coil. This Eclipse uses a distributorless system; the PCM fires the coil based on cam and crank angle sensor signals.
Conversation Summary
The owner of a 1999 Mitsubishi Eclipse non-turbo reports sputtering and lack of power on acceleration. Replacing the fuel filter did not help. The expert advised checking ignition basics first, including plugs, wires, and possibly a failing coil, and explained that many newer cars have no distributor because the PCM times coil firing from cam and crank sensors.
