2000 Mitsubishi Eclipse Highway Stumble
MITSUBISHI
EKENB403
My daughter has a 2000 Eclipse with less than 16000 miles. Normally, it accelerates and drives fine. Lately, it stumbles when being driven on the highway, between 30 and 40 MPH. Mostly, it's when you slow down and try to speed up again. But, it does'nt do this all of the time. Any help will be appreciated. Thanks
Dec 14, 2006 at 8:51 AM
CARUNDELL
  • 602 POSTS
[quote:213857d56f="ekenb403"]My daughter has a 2000 Eclipse with less than 16000 miles. Normally, it accelerates and drives fine. Lately, it stumbles when being driven on the highway, between 30 and 40 MPH. Mostly, it's when you slow down and try to speed up again. But, it does'nt do this all of the time. Any help will be appreciated. Thanks[/quote:213857d56f]
hey ekenb,
When was the last time the vehicle was tuned up? It sounds like a ignition wire or plug is failing. Let us know!
Chris
Dec 16, 2006 at 8:03 PM
KHANGMAN
Our 2001 Mirage is doing the same thing. We found if you turn off the heater fan, the stalling and hesitation stops. Very strange. Have no idea how the fan could affect the performance like that.
Dec 26, 2006 at 10:51 AM
Suggested Repair
Check when the Eclipse was last tuned up and inspect the ignition wires and spark plugs, which may be failing and causing the intermittent stumble.
Conversation Summary
The owner of a 2000 Mitsubishi Eclipse reports intermittent stumbling between 30 and 40 mph, especially after slowing down and accelerating again. An expert suggests a failing ignition wire or spark plug and asks about the last tune-up. Another owner of a 2001 Mirage reports similar hesitation that stops when the heater fan is turned off.
