1990 Mitsubishi Eclipse No Drive
MITSUBISHI
BECKYSPENCER
This is a 1990 Mitsubishi Eclipse with a 1.8 m engine. it does have an overdrive and an economy option on the transmission. My husband rebuilt the motor on this car, and when it wouldn't start, he found out the computer was burned up. He had some fellas install a rebuilt computer for $200. The car started fine and still runs fine, but ever since the installation of this board, the transmission won't work. It won't go frontwards or backwards, either one, even though before rebuliding the motor, nothing was wrong with the transmission. Is it possible that something in the computer board messed up the transmission? If so, any suggestions? Thank you! Becky
Feb 27, 2007 at 12:54 PM
CHEVY22
  • 1,375 POSTS
from what you stated it really sounds like it , im wondering if the computer was from a manual transmission ???? this will not control the auto trans you can get the codes off of both computers and call the dealer with your vin and ask them if the new ecm will fit your car
thanks , jim
oh and if you are happy with the info please leave some feedback we all donate out time here helping people for free
Feb 28, 2007 at 7:03 AM
Suggested Repair
Verify the replacement ECM is correct for this automatic-transmission Eclipse. Compare codes from the old and new computers, then confirm fitment with a dealer using the VIN. An ECM intended for a manual transmission will not control the automatic transmission.
Conversation Summary
A 1990 Mitsubishi Eclipse with a 1.8 engine ran fine after a motor rebuild and replacement of a burned computer, but the automatic transmission no longer moved forward or reverse. It had worked normally before the computer was replaced. The expert suggested the rebuilt ECM may be for a manual transmission and recommended comparing computer codes and confirming the correct ECM with a dealer using the VIN.
