2003 Mitsubishi Mirage No Spark Stalls
Leave the other one alone because you aren't doing anything except wearing out the connections.
get back to basics. You are missing spark. Let me know exactyly what you are missing and we'll go from there I suspect a coil pack bad.
A bad computer occurs in one of 5000 car problems.
Suggested Repair
Stop disconnecting the engine computer and the airbag module. If spark is missing, inspect the coil pack. Also test the throttle position sensor with the key on and engine off: the center-wire voltage should be about 0.8 to 1 volt at closed throttle and rise smoothly to about 5 volts as the throttle opens.
Conversation Summary
The owner of a 2003 Mitsubishi Mirage reported no spark and said the car would start only after disconnecting and reconnecting the computers, then stall when the throttle was opened. The expert said the module near the gear selector is the airbag computer and advised leaving both modules connected. After the owner reported idle-only running and stalling on quick throttle input, the expert recommended testing the throttle position sensor and earlier suspected a bad coil pack.
