2000 Mitsubishi Eclipse Hood Won't Open
MITSUBISHI
PENNAD
Re: 2000 Mitsu Eclipse GT 6c., 78,000 miles
Hood Release handle not engaging at all - therefore hood won't pop to allow opening. Two part question:
1. For repair, best to take to dealer (high labor costs though) or can local repair shop fix it?
2. Is there a way to manually release the hood until I get it fixed?
This is not addressed in the owners manual at all. Sure would appreciate your help on this.
Thanks,
Diane
Feb 19, 2007 at 1:39 AM
CHEVY22
  • 1,375 POSTS
sounds like the cable is binding or broken , yes a local shop can repair it ,
if you lay on your back and look above you infront of the radiator you should see the latch , if you can see it look for the cable and give it a yank if that doesnt work you may have to reach up and hit the latch to open
jim
Feb 19, 2007 at 1:47 AM
Suggested Repair
A local shop can repair a binding or broken hood-release cable. To open the hood temporarily, look up from underneath in front of the radiator, locate the latch, yank the cable if visible, or tap the latch to release it.
Conversation Summary
The owner of a 2000 Mitsubishi Eclipse GT cannot open the hood because the interior release handle does not engage. The expert says the cable is likely binding or broken and that a local shop can repair it. Until then, the latch can be reached from below in front of the radiator by pulling the cable or tapping the latch.
