1997 Mitsubishi Eclipse Gray Smoke
MITSUBISHI
DAVID718
i have mitsubishi 97 eclipse GS, when i start it, more than usual smoke comes out the tail pipe, it is not white, blue or black, just gray, but after driving about 5 min exhaust smoke is fine meaning can barely see it coming from tailpipe, what could it be
May 12, 2006 at 11:26 AM
LOSONE
  • 1,616 POSTS
For us to be able to assist you, it is absolutely necessary for you to include the make, model, year and mileage of your car. also the tranny
May 13, 2006 at 7:07 AM
DAVID718
[quote:fd74d841ad="david718"]i have mitsubishi 97 eclipse GS, 71788 miles, when i start it, more than usual smoke comes out the tail pipe, it is not white, blue or black, just gray, but after driving about 5 min exhaust smoke is fine meaning can barely see it coming from tailpipe, what could it be[/quote:fd74d841ad]
May 14, 2006 at 6:32 AM
LOSONE
  • 1,616 POSTS
Light gray smoke is a sign of a mild rich condition caused by a sensor not working properly. It needs to be scaned by a mechanic so he can read the computer data stream and see how the sensors are reacting and if you are tranfering from closed loop to open loop.
You engine has been known for early ring failure also. Good luck
May 15, 2006 at 12:40 AM
Suggested Repair
Have a mechanic scan live computer data for a mild rich condition, checking sensor response and the closed-loop to open-loop transition. Also consider possible early piston ring wear, which is known on this engine.
Conversation Summary
The owner of a 1997 Mitsubishi Eclipse GS with about 71,788 miles reports gray exhaust smoke at startup that clears after about five minutes of driving. The expert says light gray smoke can indicate a mild rich mixture from a sensor problem and recommends scanning the data stream, including closed-loop to open-loop operation. The expert also notes these engines are known for early ring failure.
