Got no idea whats wrong
MITSUBISHI
KINGSKID
1997 Mitsubishi Eclipse, 68,000 miles, 4 cylinder. I was driving it yesterday and heard a pop like noise from the hood area. A few miles down the road the car seemed to hesitate like it was going to stall, the check engine light started to flash and the car seemed to lose power. It didn't stall but the pick up was not what it was usually. The hot/cold needle went from c to the half way point almost instantaneously, never all the way to the hot. I turned on the heat and ran the fan full force. I drove it 2 miles to my house. The needle never left the half way point which it usually goes down whenthe car is in motion. After it was cool I checked the water level in the radiator and it was full. I have no idea what could be wrong and as I am not car experienced I need some advice as to what it could be before I take it to a shop and let them sell me the Brooklyn Bridge. I'm just an old woman who needs help. Thanks.
May 24, 2007 at 11:37 AM
SERVICE WRITER
  • 9,123 POSTS
I don't know what happened, but don't buy that bridge. I inject what I do know. When the check engine light flashes, it indicates that too much fuel is entering the combustion chambers and not being burned well. The rich mixture gets into the CAT. converter and is damaging it and probably causing the hesitation.
I know there is a problem with a gasket at the throttlebody that can goes bad. I would expect if it did extra air could enter, causing the computer to adjust and throw more fuel in. But that is just speculation. UHHH....Wanna buy the Grand Island bridge? :wink:
May 24, 2007 at 12:15 PM
TURBOTUFF20G
  • 98 POSTS
is it turbo?? if so sounds like you blew off an intercooler line or intake hose
May 27, 2007 at 5:58 PM
VETTECRAZY
The dealership found the issue to be spark plug wires. and nothing major at all. good luck.
Jun 9, 2007 at 12:12 PM
