2003 Mitsubishi Galant Check Engine Light
I agree....buy it, use it and return it the next day. post the code and we will help you find your problem...sometimes disconnecting the battery for a minute will reset your check engine light...it works on my 98 Eclipse when my sensors go bad, of course if you dont fix the issue first it will bring the light back on.
Suggested Repair
Read the check engine light with an OBD-II code scanner and use the code for further diagnosis. A switch to regular gas is unlikely to be harmful, though a sensor fault is possible. The gas cap was already checked. Disconnecting the battery may clear the light temporarily, but it will return if the fault is not fixed.
Conversation Summary
The owner of a 2003 Mitsubishi Galant with about 58,000 miles normally uses mid-grade or premium fuel. After a relative filled the tank with regular gas, the check engine light came on and stayed on after the gas cap was checked. Experts said the fuel change was unlikely to cause harm but a sensor could be affected, and advised scanning for the diagnostic code before further repair. A battery disconnect may reset the light only temporarily.
