You need a scanl tool read the pressure
Dunno what liter engine
12 valve 3.4-5.3 psi
24 " 3.6-5.6 psi
If not in range-replace MDP sensor
If the wires checks out for a short or open circuit with good ground to it do below:
Turn key to On and measure the voltage at connector terminal no.3 if its not 4.8-5.2volts replace the computer. If it is replace MDP sensor.
SPONSORED LINKS
Wednesday, August 15th, 2007 AT 7:09 PM
