2003 Mitsubishi Eclipse GT Check Engine Light Fix
MITSUBISHI
GREENMELLON
I just installed a short ram intake on my 03 eclipse GT and now my Check Engine Light won't go off. I already disconnected the battery and that didnt work. Any suggestions? Also now the i have the intake on there i am getting black residue where my exaust is. Any ideas what that could be?
Jan 28, 2006 at 11:36 AM
2CARPRO JACK
  • 11,533 POSTS
Needs to have the codes cleared with a scanner. The soot is from mixture problems( probably the source of the check engine light)
Jan 31, 2006 at 9:52 AM
Suggested Repair
Clear the trouble codes with a scanner. The black exhaust residue is soot from air-fuel mixture problems, which is likely also causing the check engine light.
Conversation Summary
After installing a short ram intake on a 2003 Eclipse GT, the check engine light stayed on despite disconnecting the battery, and black residue appeared at the exhaust. The expert advised clearing the codes with a scanner and attributed the soot to mixture problems, likely the source of the light.
