Mitsubishi Montero Sport Cuts Off
MITSUBISHI
REDMONEY32
HELLO I CHANGED THE ALTERNATOR,DID A TUNE-UP,BOUGHT BATTRY,CHANGE THE IDLE CONTORL VALVE,AND MY CAR STILL CUTS OFF,WHATS THE PROBLEM CAUSING THIS.I NEED HELP.,I HAVE 200,MITSUBISIH MONTERO SPORT.
Aug 10, 2007 at 5:38 AM
  • 75,988 POSTS
[quote:6f99201896="redmoney32"]HELLO I CHANGED THE ALTERNATOR,DID A TUNE-UP,BOUGHT BATTRY,CHANGE THE IDLE CONTORL VALVE,AND MY CAR STILL CUTS OFF,WHATS THE PROBLEM CAUSING THIS.I NEED HELP.,I HAVE 200,MITSUBISIH MONTERO SPORT.[/quote:6f99201896]
Do a fuel pressure check with a gauge and comeback with the results-lets do fuel system 1st then we'll take it step by step once ruled out we go to the next phase.
When it cuts out do u have problem/s starting it back up.
Aug 11, 2007 at 2:43 PM
Suggested Repair
Check fuel pressure with a gauge and report the results before moving to other systems. Also note whether the engine is hard to restart after it stalls.
Conversation Summary
The owner of a Mitsubishi Montero Sport replaced the alternator and battery, performed a tune-up, and changed the idle control valve, but the engine still cuts off. The expert recommends starting with a fuel pressure test and asking whether restarting is difficult after it stalls.
