airbag light is always on
MITSUBISHI
AMITABHSINHA9
make : mistsubhishi
model: mirage
year: 1997
mileage: 85k
my airbag light is always on. some of my friend said becoz it is 10 year old i may have to reset some switch. is this true? or there can be any other problems? how much cost it take to fix it?
Dec 13, 2006 at 1:21 PM
BACKYARDMECHANIC
  • CAR REPAIR CONTRIBUTOR
  • 337 POSTS
If the airbag light is on then there is a problem with the airbag system. There is most probably and open wire or defective sensor with in the airbag circuit. A word of caution if you are going to work on this yourself. Be carful you don't accidently set off the air bags. Good luck :)
Backyardmechanic
Dec 13, 2006 at 2:08 PM
