95 Mighty Max
FAH
  • 1995 MITSUBISHI
I have a 95 mitsubishi mighty max with 250000 miles on a 4 cyl 2.4 engine. Today when I tried to start my truck the dummy lights came on like normal but it would'nt start, no clicks, nothing. I push started it and got it home. When I got it home I shut it off then hit the ignition and it started right up. My question is, is there a clutch/starter linkage that may have caused this or is this the sign of a dying starter solenid?
Wednesday, May 30th, 2007 AT 1:53 PM
JAVA MOTORSPORTS
  • 52 POSTS
They have a clutch switch that will not let the truck start if the clutch is not pressed all the way down. Sometimes they short out and will not let the truck start. However it could still be your starter I would try the switch first.
Wednesday, May 30th, 2007 AT 3:38 PM
