1993 Mitsubishi Eclipse Tail Lights Cold
1993 MITSUBISHI
BRUCE316
Directional and brake lights don't work on right rear of car when vehicle is cold. Running lights work. When inside of car is warm (sits all day in sun), they work. Bulbs are new. Acts like a bad ground, but don't know where to look. Any Suggestions?
Nov 9, 2007 at 9:21 AM
  • 75,988 POSTS
The black wire that goes to every light bulb socket is the ground wire that teminates at G407. Your main ground termination point is located at G407 center rear of trunk
https://images.2carpros.com/forum/automotive_pictures/12900_mits_tail_wiring_1.jpg
Nov 9, 2007 at 9:54 AM
Suggested Repair
Inspect and clean the tail-light ground at G407, located at the center rear of the trunk. The black wire at each bulb socket is the ground and terminates there.
Conversation Summary
The owner of a 1993 Mitsubishi Eclipse reports that the right rear turn and brake lights fail when the car is cold but work after it warms in the sun. Running lights work and the bulbs are new, suggesting a ground problem. The expert says the black wire at each bulb socket is the ground and terminates at G407 in the center rear of the trunk.
