91 Mit. 3000GT VR4 stalling
2012 MITSUBISHI
SUNSHINESC
My 91 3000GT VR4, 112000 miles, stalls after 3 seconds. Replaced fuel pump and fuel filter and it still won't run after 3 seconds. It sounds like a relay or sensor in the engine is clicking when starting the engine. It has 1/2 tank of gas. Any ideas?
Nov 7, 2007 at 2:45 AM
BLACKOP555
  • 10,386 POSTS
the clicking may be the fuel injectors clicking. Check for fuel pressure at the fuel rail. if none check for voltage at fuel pump connector if none check the relay and the fuse, also cracked wires or corroded connectors.
Nov 7, 2007 at 6:07 AM
