1995 Mitsubishi 3000GT Timing Belt Loose Fix
MITSUBISHIGTOVR4
1995 Mitsubishi 3000gt. mileage:100,000. Hi, im having a problem with tension on my timing belt, it all started when my timing belt started burning. I took it to a shop right here 2 blocks away from my house they told me that the waterpump completely frozen, I took a look at it and tried to turn the wheel and it was stuck. So they replaced the timing belt and the water pump but when they put it back together the belt was all loose, they said it would need a new tensioner, so they relaced it and the belt got tight and it worked good but the next morning I checked the belt and it was all loose again! I took it back and they said it was a manufacturers defect so they replaced the tensioner again and it was tight again and it worked good but again after the engine cooled down it got loose again, why does it lose its tension? is there another tensioner hidden somewhere else? or is ther some kinda trick to fix this?
Jan 19, 2006 at 6:01 AM
2CARPRO JACK
  • 11,533 POSTS
some of those have an eccentric that you pre-tension with before pulling the pin out of the hydraulic tensioner
Feb 9, 2006 at 9:50 AM
Suggested Repair
On these engines, pre-tension the eccentric before pulling the pin from the hydraulic timing-belt tensioner so the belt holds tension after the engine cools.
Conversation Summary
A 1995 Mitsubishi 3000GT lost timing-belt tension after a frozen water pump was replaced with a new belt and tensioner. The belt tightened after each tensioner replacement but loosened again once the engine cooled. The expert said some of these use an eccentric that must be pre-tensioned before the hydraulic tensioner pin is pulled.
