1997 Mitsubishi engine light
DEVIN85
  • 1997 MITSUBISHI
Engine problem
1997 Mitsubishi V6 Two Wheel Drive Manual 110000 miles
I have a 1997 mitsubishi 3000gt with 110,000 miles, my check engine light is on and the problem I notice is my car will stall if I hit the clutch at to high a rpm, I have have changed my mass air flow sensor and manifold absolute pressure sensor an that didnt help, only thing left is my o2 sensor but when I had it checked by a mechanic his computer told me it was the manifold absolute pressure sensor. Can you please help?
Monday, December 3rd, 2007 AT 7:06 PM
  • 31,937 POSTS
Hi there, have the fault codes erased and drive car. Re check for codes. If MAP sensor has triggered a code, first look for any vacuum leaks, as this will upset the MAP sensor. Check that the TPS is with in specification, and on live stream data collection, the throttle % is accurate.
Mark (mhpautos)
Monday, December 3rd, 2007 AT 8:54 PM
