1991 Mitsubishi 3000GT Stalls
2012 MITSUBISHI
SUNSHINESC
My 91 3000GT VR4, 112000 miles, stalls after 3 seconds. Replaced fuel pump and fuel filter and it still won't run after 3 seconds. It sounds like a relay or sensor in the engine is clicking when starting the engine. It has 1/2 tank of gas. Any ideas?
Nov 7, 2007 at 2:45 AM
BLACKOP555
  • 10,386 POSTS
the clicking may be the fuel injectors clicking. Check for fuel pressure at the fuel rail. if none check for voltage at fuel pump connector if none check the relay and the fuse, also cracked wires or corroded connectors.
Nov 7, 2007 at 6:07 AM
Suggested Repair
Check fuel pressure at the fuel rail. If there is none, check voltage at the fuel pump connector. If voltage is missing, inspect the fuel pump relay, fuse, and look for cracked wires or corroded connectors. The clicking may be the fuel injectors.
Conversation Summary
The owner of a 1991 Mitsubishi 3000GT VR4 reports that the engine stalls after about three seconds. The fuel pump and fuel filter were already replaced, the tank is half full, and a clicking sound is heard when starting. The expert says the clicking may be the fuel injectors and recommends checking fuel rail pressure, then pump connector voltage, the relay, fuse, and wiring or connectors if pressure or voltage is missing.
