1997 Other Mitsubishi Models Loosing Engine Coolant
1997 MITSUBISHI
11,000 MILES • 4 CYL • FWD • AUTOMATIC
MJED0
I have an automatic 2.0L 1997 Mitsubishi Spacewagon that keeps loosing all its coolant once every 1-2 weeks. The leak is coming from the tube out of the overflow tank and only it leaks in the first 2-3 minutes after shutting the motor off, and only if the motor was completely warmed up. The only time it leaks while running is if I'm caught in traffic (stop and go), and it stops leaking once I get going again. I can drive for hours around town or at 50-60 MPH on the highway and not loose a drop.
So far I have replaced the rad cap, removed the thermostat and flushed the rad a couple times, all to no avail.
Any help in this problem would be greatly appreciated.
Thanks,
Dan
Jul 29, 2008 at 4:46 AM
  • CAR REPAIR CONTRIBUTOR
  • 31,937 POSTS
Hi there,
I would have the radiator professionally cleaned & flow tested, as it may have blocked cores, you will still get circulation but often they can be up to 50% blocked
Mark (mhpautos)
Jul 29, 2008 at 5:02 AM
