1998 Other Mitsubishi Models LEAKING
1998 MITSUBISHI
110,000 MILES • 4 CYL • FWD • MANUAL
DWPHILLIPS65
Why does the car leak coolant and oil?
Dec 26, 2008 at 10:51 AM
  • 31,937 POSTS
HI there,
All engines are reliant on gaskets, seals to stop fluids leaking, with the coolant you can get a cooling system pressure test done to help locate external leaks, as for the oil wash down the engine and check for fresh oil leaks around the rocker cove gasket front &real crank shaft seals drain plug, oil pressure sender and oil filter as these are the normal placed that leaks develop, start here.
mark (mhpautos)
Dec 26, 2008 at 8:57 PM
