2002 Mitsubishi Galant Coolant Leak
MITSUBISHI
JGOLDEN30
I noticed a leak of anti-freeze today on my 2002 Mitsubishi Galant es....it currently has 95000 miles on it. Before I saw this leak, I was having trouble with the car's heat working properly. It didnt want to heat up.
thank you
Apr 7, 2007 at 11:08 AM
LILWILLS
  • 49 POSTS
where was the leak and what kind of problems do you have with the heat
Apr 7, 2007 at 1:45 PM
JGOLDEN30
Thanks for replying. The leak is in the front right of the car. The heat took a lot longer to work and while I was just sitting at a light or not accelerating it was not very warm. I have been smelling the anti freeze for a couple weeks but this is the first time I actually saw it on the ground.
Thank you
Apr 7, 2007 at 3:06 PM
  • 55,770 POSTS
You get no heat because the coolant level is low and the heater core is higher up. check your coolant level COLD ONLY!, and repair the leak, it sounds like a radiator leak to me, please get back to me.
Apr 7, 2007 at 4:01 PM
LILWILLS
  • 49 POSTS
any problem with overheating or it not heating up
Apr 7, 2007 at 4:02 PM
Suggested Repair
Check the coolant level only when the engine is cold, then repair the leak. The front-right leak and weak heat are consistent with a radiator leak and low coolant, which can leave the higher heater core without enough coolant.
Conversation Summary
The owner of a 2002 Mitsubishi Galant ES with about 95,000 miles reported an antifreeze leak at the front right and weak heat, especially at idle, after smelling coolant for weeks. The expert said low coolant can prevent heat because the heater core sits higher, advised checking the level only when cold, and suspected a radiator leak that should be repaired.
