1994 Other Mitsubishi Models engine and tranny swap
1994 MITSUBISHI
WGOTHBERG
I have a 1994 Mighty Max with an excellent engine and drive train but a wasted body from being T-boned. I have an opportunity to get very cheaply a 1989 Mighty Max with a wasted engine but an almost mint perfect body. How feasible would it be for me to swap or have swapped the good 1994 guts into the good 1989 body?
Jun 1, 2008 at 4:59 PM
2CARPRO JACK
  • 11,533 POSTS
Might want to research your states smog laws first, may turn out to be a headache.Since both are OBD-1, if you swapped the entire wiring harness and ECM for the engine trans it may work, need to see if the new one needs more fuel pressure (different pump) and swap all the evap out (depending on smog laws)
Jun 2, 2008 at 1:04 AM
