1993 Other Mitsubishi Models truck won't start
GOTHMOOGJADOG
  • 1993 MITSUBISHI
  • 4 CYL
  • MANUAL
  • 175,000 MILES
I have been working on this truck for days. It all started when I had a power steering belt start to slip on me I went to get the belt and replaced it but when I went to start the truck to no avail it did not start. So I replace the plugs, wires, cap and battery. Got spark still no start. Engine turns over no problem. Took apart the top half of the engine so that I may reach the fuel rail. Fuel squirting in my face so I have fuel pressure. So it must be a sensor but I am lost on which one and I am unsure weather I can hook this truck up to a diagnostic or not. Please help. This is a 1993 Mitsubishi Mighty Max 4cyl rear wheel drive standard trans
Sunday, October 26th, 2008 AT 2:37 PM
TECHNOPRO
  • 45 POSTS
[Hi,
May be you should check the timing marks and see if they are all on marks.
What engine is your truck fitted with? 4G54, 4G63?
Cheers.
Monday, October 27th, 2008 AT 6:23 AM
GOTHMOOGJADOG
I tore it down to the timing belt and only the gear is marked though when cranking over I noticed the all the pulleys have a delay when the belt spins does that mean I am outta time or is that delay supposed to go on and I will find out the engine numbers
Monday, October 27th, 2008 AT 1:58 PM
TECHNOPRO
  • 45 POSTS
Hi there,
can you feel that the timing belt is tight?
Give me the engine number and I'll be able to find some timing marks and procedures for you.
Cheers.
Tuesday, October 28th, 2008 AT 5:06 AM
GOTHMOOGJADOG
4g54 is the engine number and under inspection the timi9ng belt tensioner has blown its berrings so it needs replaced almost positive that it is out of time. Thank you so much for you time and your help
Tuesday, October 28th, 2008 AT 11:46 AM
