Water leaking from the evaporator drain tube
MR JAY
  • 2001 MITSUBISHI GALANT
  • 4 CYL
  • 88,000 MILES
Water leaking from the evaporator drain tube. Had compressed air blown in but it still leaks in my driver's side flooring. I have to put a rag underneath where the leak goes. I don't know what to do. Please help.
Monday, August 30th, 2010 AT 7:57 AM
KHLOW2008
  • 41,814 POSTS
Hi mr jay,
If water is accumulating, the drain hose is clogged and you woudl need to use a wire or other similar equipments to dig into the drain hole after removing the hose.
Compressed air sometimes donot work as debris inside would only move away and when water accumulates, the debris would be washed onto the drain hole clogging it again.
Wednesday, September 1st, 2010 AT 1:25 PM
ELGATOS63
I had the exact same problem with mine, I also have a '01 galant, after many moons trying to find out what the problem was, (hangers, compressed air, pipe cleaners) I found a TSB on this, I dont have the number but the problem is a bad FOAM seal between the evaporator and firewall, they should have used rubber I think, I just pulled the carpet back and globbed silicone around the tube where it goes into the firewall and that fixed the problem. I hope this helps
Wednesday, October 6th, 2010 AT 9:40 PM
CRISTILUV SANDERS
I have a 2001 Mitsubishi gallant my air conditioning works great and now it goes in and out randomly does anyone know what that may be? I realize that I'm bit off the topic my car isn't leaking or draining but if it would be great if anyone could help.
Tuesday, May 23rd, 2017 AT 1:21 PM
KEN L
  • MASTER CERTIFIED MECHANIC
  • 54,333 POSTS
Hi there,
Please post your new question here
Cheers, Ken
Friday, May 26th, 2017 AT 2:56 PM
MADAMS1202
  • 6 CYL
  • FWD
  • 120,000 MILES
Air Conditioning problem
2001 Mitsubishi Galant 6 cyl Front Wheel Drive Automatic 120000 miles
I need to know exactly where (Pictures if possible) the condensation drain is located. I've looked at the firewall for a small elbow shaped hose pointing downward to no avail.
Friday, May 26th, 2017 AT 2:57 PM (Merged)
SATURNTECH9
  • 30,869 POSTS
Which model galant do you have also do you have a manual a/c or climate control?
CRISTILUV SANDERS
A 4 cylinder and I don't believe it's climate control.
MAINT4MAN
  • 2003 MITSUBISHI GALANT
  • 6 CYL
  • FWD
  • 80,000 MILES
2003 Mitsubishi Galant 6 cyl Front Wheel Drive Automatic 80,000 miles
I have water pooling in the floorboards and a noise in the fan when I make a left turn, it is apparent that the condisant drain is plugged, but I have been unable to locate from under the vehicle. Can you point me in the right area so I can blow it out and get it draining again?
Thanks!
DOCFIXIT
  • 18,828 POSTS
Look on the passenger sid bulk head down arout 6" or up from where it starts to curve up from the floorboard. Hose down turned to ground.
Hope this helps
You might want to to take door trim off and lift carpet up to dry
