2005 Mitsubishi Galant Air conditioning shuts off when fan
2005 MITSUBISHI GALANT
DJANKOR
Air Conditioning problem
2005 Mitsubishi Galant 4 cyl Two Wheel Drive Automatic
When fan control is set to 1 the AC light comes on and the compressor runs, as soon as I turn it to 2 or above the light goes off and the compressor shuts off. Freon level is good....
Thanks
Don
Aug 28, 2010 at 8:07 AM
KHLOW2008
  • 41,814 POSTS
Hi djankor,
If the A/C blower motor works only on 1st and highest speed, the most likely cause is a bad blower resistor. If only 1st speed is working, then it could be a faulty switch.
Sep 1, 2010 at 6:20 AM
