Air Conditioning problem
2001 Mitsubishi Galant Two Wheel Drive Automatic
my mothers car is leaking water in the back floor board on the driver side. How do we find the hose to fix it?
Tuesday, July 27th, 2010 AT 3:38 PM
MERLIN2021
MECHANIC
The evaporator core is on the passenger side, look there under the car. Is the passenger floor wet? Peel the rug back for a good look.
SPONSORED LINKS
Tuesday, July 27th, 2010 AT 3:40 PM
TAMMI BARGAS
MEMBER
I belive she said its just leaking on back floor board on driver side
Tuesday, July 27th, 2010 AT 3:48 PM
MERLIN2021
MECHANIC
The floor pan is designed to have the water flow into the back, but it MUST pass from the front to get there, so I believe if it is wet from the A/C drain, the front passenger carpet will be wet, or the leak is from some place else, so you need to figure that out before you fix the wrong problem!
