1989 Mitsubishi Galant Car won't start
VISIONZINT
  • 1989 MITSUBISHI GALANT
Engine Performance problem
1989 Mitsubishi Galant 4 cyl Front Wheel Drive
Can't figure out why my car won't start. I replaced the alternator because it wasn't giving out enough charge and drained the battery. I've also had the starter tested and put new plugs, wires, coil and distributor cap on in the last few months. It's getting spark and I can hear the fuel going into the throttle body but all the engine does is rotate. I've been told to check the MAP sensor but now I hear I don't have one on this car(?) I've also cleaned the EGR valve and Mass Air Flow and neither of these helped a bit. Trying not to get taken by a mechanic cause I have no idea what it could be. Anyone have any ideas?
Tuesday, January 6th, 2009 AT 7:55 PM
KHLOW2008
  • 41,814 POSTS
Hi Visionzint,
If you have fuel and sparks, the next thing to check would be the compression.
Fuel might be available at rail, but are they getting past the injectors? Get some starting fluid into throttle body and test if it starts.
Friday, January 9th, 2009 AT 8:22 AM
