Hi jkilger,
Thank you for the donation.
Seems the shift cables are out of adjustment. Here are the procedures for checking and adjusting if required.
ADJUSTMENTS
GEARSHIFT LEVER & SHIFT CABLE
1 . With transaxle select lever in "N" position, move gearshift lever into 4th gear. It may be necessary to depress clutch pedal. Loosen shift cable adjuster nuts (inside of vehicle).
2 . Disconnect cable end from shift lever pin. Tilt gearshift lever into 4th gear position. Hold lever in this position, and adjust shift lever cable until it aligns with shift lever pin. Ensure cable bushing faces cotter pin.
3 . Move shift lever between all gear positions. Ensure shift lever operates smoothly. Road test
vehicle to ensure proper adjustment and smooth shifting.
SELECT CABLE
Place transaxle- side shift lever in Neutral. This will also place transaxle- side select lever in Neutral.
Loosen selector cable adjuster nuts (inside of vehicle).
With select lever in Neutral, adjust select cable end until eye fits easily over select lever pin. Tighten
adjuster nuts.
SPONSORED LINKS
Monday, September 21st, 2009 AT 3:14 AM
