1997 Mitsubishi Eclipse 4 cyl Front Wheel Drive Manual 0
Just had the engine in my 97 eclipse 240A non-turbo, rebuilt. Drove the car into the shop. Shop is a eclipse specialty shop, but does not do a lot of 240A engines.
Put the engine back in. It has fuel to the rail, and we are recording signal from the cam and crank sensors, but are not getting any spark.
Timing has been triple checked. We have checked to see that all fuses, relays and connections are tight and not blown.
No error codes detected.
From my on-line research this appears to be a fairly common issue with the eclipse, but I can't find any answers that have worked.
Friday, July 16th, 2010 AT 7:10 PM
