Hey, My car will run perfectly for about 15 minutes then it gets hot and starts to leak anti-freeze from behind the engine, its leaking onto my ehausht pipe causing steam. I have changed the radiator, cap, thermostat, water pump, timing belt and oil and it still overheats. The fans come on and work properly, What else could it be please help! Thanks
SPONSORED LINKS
Wednesday, August 5th, 2009 AT 9:59 PM
