When coolant level drops, topping up is not sufficient. You need to let it run for a while with the radiator cap off to bleed the system and keep topping up till the level maintains.
When minor leaks occurs, it seldom are the hoses. It could be joints, water pump etc. A pressure test would enable you to locate the source of the leak.
Thursday, April 22nd, 2010 AT 11:01 AM
