1995 Mitsubishi Eclipse 1995 eclipse white smoke coming out
120,065 MILES • 4 CYL • FWD • MANUAL
ORLANDO210
I have a 1995 eclipse blowing white smoke out of tail pipe after car idles for about 5 mintues.I checked all of the levels oil,and water and they are at normal levels. I went by autozone and they said that it might be the transmission module that is bad and would need to be changed have you heard anything about this thank you
Mar 24, 2009 at 7:44 PM
ZACKMAN
  • 4,202 POSTS
Have you performed the pressure test on the block as suggested by my colleague, Rasmataz on March 18? That is the best way to check for white smoke, usually caused by coolant in oil.
https://www.2carpros.com/forum/1995-mitsubishi-eclipse-1995-mitsubishi-eclipse-white-smoke-vt274051.html
Mar 28, 2009 at 7:55 PM
