My eclipse wont start I have put in a new starter and battery everytime I try to start the car all you here is the starter clicking you turn the key it clicks thats it. Even when we try to pull start it the engine dont wanna turn over this just happended yesterday it was running fine just the starter was bad so I replace it and the battery like I said and it started fine everything worked fine and today when I went to go start it it just wouldnt start could it be the maf sensor?
SPONSORED LINKS
Saturday, January 9th, 2010 AT 2:50 PM
MECHANIC
No crank at all/nothing/nada:
Could be the starter, starter relay, park and neutral switch, clutch switch and ignition switch assuming the battery and connections are good.
