1994 Mitsubishi Diamante ALTERNATOR REMOVAL
TRUTH153
Electrical problem
1994 Mitsubishi Diamante 6 cyl Front Wheel Drive Automatic
Got it loose how do i get it out?
Apr 26, 2009 at 12:49 PM
BLUELIGHTNIN6
  • 16,542 POSTS
Before removing the alternator and bracket assembly from the engine, loosen the assembly bolt by which the alternator is fixed at the alternator bracket. There is only a small amount of room in which to take out the alternator so you will have to work very carefully with it to prevent damaging nearby components.
NOTE: If this is a SOHC engine then remove the alternator through the transaxle side, through the bottom of the intake manifold plenum.
Thanks for using 2CarPros.com!
Apr 26, 2009 at 12:56 PM
