Misfiring
1,111,111 MILES • V8 • 4WD • AUTOMATIC
THOMAS808
  • 46 POSTS
Hello everyone.I have the truck listed above with a 460.
I change 2 fuel pumps and the hole distributor. now it does not want to start it just misfires like, so I got a coil and still the same.I have lots of gas going in. it sounds like it want to start but it's just misfiring.so I wonder if it could be the ignition switch??I really don't no what else to do.
Apr 18, 2021 at 3:25 PM
Good morning,
This could be from injectors that are are not flowing fuel or enough fuel into the engine from being clogged. There is no additive that will clean them. With the age of the truck, they may have to be replaced. I attached the procedure below for removing the fuel manifold for you.
https://www.2carpros.com/articles/how-to-replace-a-fuel-injector
https://www.2carpros.com/articles/how-to-test-a-fuel-injector
Also, I attached the wiring diagram for you as well for the ignition system. With the key in the on position, check the voltage at the positive side of the coil for battery voltage.
Apr 18, 2021 at 6:26 PM
THOMAS808
  • 46 POSTS
Good morning.I even put fuel in the card and it still does not start.I just got a brand new coil and still yet.i do not know what else to do.I pretty much put everything brand new; fuel pump, two of them, brand new distributor, brand new coil, and it does not want to run.even if I poor gas in the carburetor it wants to start but pop a little. I checked the fuel leader and it has a lot of pressure.
Apr 19, 2021 at 3:49 AM
Okay, did you verify voltage to the coil as I suggested in the previous post?
I would also check the compression to be sure the timing is correct. You should have 140 -160 pounds.
Apr 19, 2021 at 5:27 AM
THOMAS808
  • 46 POSTS
Yes, I got compression. Timing is correct.and I just got a brand new coil.
Apr 19, 2021 at 7:01 AM
What is the compression?
What is the voltage at the coil that I requested?
Apr 19, 2021 at 7:05 AM
THOMAS808
  • 46 POSTS
It's 150 compression.never check the coil yet.
Apr 19, 2021 at 7:15 AM
Let me know the results.
Apr 19, 2021 at 7:19 AM
THOMAS808
  • 46 POSTS
Thank you so much.I really appreciate it.
Apr 19, 2021 at 7:24 AM
THOMAS808
  • 46 POSTS
It's not popping now just crank.
Apr 19, 2021 at 7:27 AM
You are welcome.
Always glad to help.
Apr 19, 2021 at 7:28 AM
THOMAS808
  • 46 POSTS
So wired, it does not pop now.I can't get a tester right now.they don't have it in stock where I live in Maui.I have strong blue spark though.
Apr 19, 2021 at 7:32 AM
Okay, let me know when you get the tester so we can do some voltage checks.
Apr 19, 2021 at 8:03 AM
THOMAS808
  • 46 POSTS
Okay, I will do.it's weird because it used to pop when try cranking and now it doesn't at all.
Apr 19, 2021 at 8:10 AM
Okay, sounds good.
https://www.2carpros.com/articles/engine-backfires-while-running
Apr 19, 2021 at 8:27 AM
THOMAS808
  • 46 POSTS
Is there any other MSD ignition discharge 6a.6200 that I can use besides the same kind?
Apr 20, 2021 at 7:21 AM
Let us cross one bridge at a time. I still need results on voltage checks to determine the reason for this not running.
Apr 20, 2021 at 7:29 AM
THOMAS808
  • 46 POSTS
Hey buddy.thank you.don't have any power to none of it .so I'm waiting for get a new MSD then I can check the voltage like you ask. There is no power going into it at all the wire is dead goes to the coil it comes from the MSD ignition discharge box.
Apr 20, 2021 at 7:38 AM
It should come from the ignition switch to the MSD box. Did you verify this?
Apr 20, 2021 at 7:40 AM
THOMAS808
  • 46 POSTS
I'll send you a picture when i crank the motor the power should have.but there is not.only get power on the the MSD no power coming out from the MSD.
Apr 20, 2021 at 7:45 AM
Okay, take a few and post them for me to see.
Apr 20, 2021 at 7:47 AM
THOMAS808
  • 46 POSTS
Hey Roy I'm sorry but this site is slow. can you ten if if can?8082839342.and I can send you pictures.
Apr 20, 2021 at 7:54 AM
THOMAS808
  • 46 POSTS
I got no power coming out wen I crank the motor.
Apr 20, 2021 at 8:02 AM
Power coming out of where?
I wish you would go back to basics and do some voltage testing instead of jumping all over the place.
Apr 20, 2021 at 8:13 AM
THOMAS808
  • 46 POSTS
Okay, so what I did is bypass the msd box.so I'm back to square one.have power on coil and now it's back to wanna start .it's little popping so will see if get plan fuel.
Apr 20, 2021 at 8:24 AM
Use a test light on the negative side of the coil. While cranking, the test light should flash.
Apr 20, 2021 at 8:41 AM
THOMAS808
  • 46 POSTS
Yes I got power now.so will try an set the timing again.
Apr 20, 2021 at 8:47 AM
THOMAS808
  • 46 POSTS
We had it on 154.now we going try 13726548.
Apr 20, 2021 at 8:48 AM
Again, you are all over the place. Can you tell me if the test light flashes on the negative side with the engine cranking?
Apr 20, 2021 at 8:52 AM
THOMAS808
  • 46 POSTS
Yes it does.
Apr 20, 2021 at 8:54 AM
THOMAS808
  • 46 POSTS
This thing is slow responding.
Apr 20, 2021 at 8:55 AM
Okay, then the module and pick-up coil are good.
I have responded in minutes when you post.
The backfiring usually comes from the timing. Did you set the distributor on number 1 compression when you installed it?
Apr 20, 2021 at 8:58 AM
THOMAS808
  • 46 POSTS
Yes I did that.
Apr 20, 2021 at 9:01 AM
Recheck it as you may have it in 180 degrees out.
Apr 20, 2021 at 9:05 AM
THOMAS808
  • 46 POSTS
Rechecked the number one compression/distributor.
Apr 20, 2021 at 9:10 AM
Correct. And make sure the rotor is pointing to the number 1 cylinder in the cap.
Apr 20, 2021 at 9:13 AM
THOMAS808
  • 46 POSTS
Yes it's on number one an jus pop..even if we out gas in side.what we did is try jump the fuel pump for more fuel an it did the same.
Apr 20, 2021 at 9:45 AM
I understand but if you have fuel and spark, the only thing left is either compression or timing. It is one of those 2 items.
Apr 20, 2021 at 9:49 AM
THOMAS808
  • 46 POSTS
Yes.I will keep trying an see what happens,.ther is 2 firing orders.
Apr 20, 2021 at 9:52 AM
THOMAS808
  • 46 POSTS
Can you please send me a link with the
Find order? so I can see if it's the same and with the distributor cap numbers and wires please.
Apr 20, 2021 at 10:01 AM
Only one for the 460. I posted it below.
The other firing order was for the 5.8 motors.
Apr 20, 2021 at 10:02 AM
