Codes P0300 and P0302, misfiring, RPM's fluctuations on cold start
DRFIROJTADAVI
  • 33 POSTS
Today check engine light came on and having code p300 and p304. As previously it was P302 constantly for last 6 months.
Wednesday, January 6th, 2021 AT 7:08 PM
KEN L
  • MASTER CERTIFIED MECHANIC
  • 47,643 POSTS
Yes, did you service the throttle bore? also we should check for a vacuum leak. this guide can help:
if no leak I would get a new MAF sensor as well.
Thursday, January 7th, 2021 AT 11:25 AM
DRFIROJTADAVI
  • 33 POSTS
I will check vacuum leaks again. I have replaced the throttle body and MAF sensor before this problem approximately 2 months before still do I need to replace it?
Thursday, January 7th, 2021 AT 11:44 AM
KEN L
  • 47,643 POSTS
Not really, I am leaning toward the vacuum leak.
Thursday, January 7th, 2021 AT 12:10 PM
DRFIROJTADAVI
  • 33 POSTS
Okay, I will let you know.
Thursday, January 7th, 2021 AT 12:23 PM
DRFIROJTADAVI
  • 33 POSTS
At cold start when misfiring and RPM fluctuations occurring the advance timing for cylinder number 1 is negative (retarded) 13-15 degrees, when the advanced timing becomes positive around 5-10 degrees the rpm stabilise. Is it normal or its having issues of ignition timing?
Friday, February 5th, 2021 AT 10:50 AM
