Mileage display error
2002 BUICK RENDEZVOUS
90 MILES
CMALIKA
Hello, I am experiencing a problem with my odometer reading error. It looks like you had information that could help figure out how to fix this.
Sep 27, 2018 at 2:42 AM
Good afternoon.
From your description, it looks like an issue with the cluster. I attached a description of the system below.
The IPC contains a season odometer and a trip odometer. Press the trip/reset switch for one second on the IPC in order to toggle between the season odometer and the trip odometer.
The IPC displays the vehicle mileage and trip mileage as determined by the IPC. The IPC calculates the mileage based on the vehicle speed signal circuit from the PCM. The odometer will display ERROR if an internal IPC memory malfunction is detected or there is a class 2 communication fault. The odometer displays either miles or kilometers as requested by the activation of the English/metric button on the Driver Information Center (DIC). The associated indicator (km or MI) illuminates.
Sep 27, 2018 at 2:57 AM
