odometer error
MATTI5475
  • 20 POSTS
Electrical problem
2002 Buick Rendezvous 6 cylinder Two Wheel Drive Automatic 83,839 miles.
i just had my engine replaced and i now get an error message on my odometer. Do i have to go to the dealer to fix this?
Feb 4, 2008 at 9:09 AM
MATTI5475
  • 20 POSTS
[quote:ad21d7d4f1="matti5475"]Electrical problem
2002 Buick Rendezvous 6 cyl Two Wheel Drive Automatic 83839 miles
i just had my engine replaced and i now get an error message on my odometer. do i have to go to the dealer to fix this?[/quote:ad21d7d4f1] obd2 does not read bcm codes.
Feb 4, 2008 at 12:25 PM
DENNYP
  • 1,824 POSTS
I would suggest having it scanned with the proper scan tool before resetting the BCM. If you are having an intermittent fault, you will erase any stored data on the fault when you reset the BCM. If you find some codes, post them for me so I can try and help you out.
Feb 4, 2008 at 1:44 PM
MATTI5475
  • 20 POSTS
[quote:e0b1904a54="dennyp"]I would suggest having it scanned with the proper scan tool before resetting the BCM. If you are having an intermittent fault, you will erase any stored data on the fault when you reset the BCM. If you find some codes, post them for me so I can try and help you out.[/quote:e0b1904a54]
thanks for all the help guys. i will see if i can find someone with a good scan tool. i will post codes if i find any. i am thinking that they may have reset it already. the guy who did the motor said he had dropped the cradle to do the engine on it, so i think he unhooked some of the wire harness. Thanks
Feb 5, 2008 at 1:14 AM
MATTI5475
  • 20 POSTS
i could not find any friends with a tech2 to scan this. so i went the other route i pulled the bcm fuse in the front power box and it did nothing.. it still reads error in the odometer where the miles would be. i think at this point i will just have to go and dump some more money into this GM gem. Thanks.
Feb 5, 2008 at 8:59 AM
BMRFIXIT
  • 19,053 POSTS
Was the BCM replaced? Snap On scanner or similar will do just fine to get the codes.
Feb 5, 2008 at 11:11 AM
MATTI5475
  • 20 POSTS
bcm was not replaced, a friend of mine that works at a local garage said his Snap On scanner would not be able to read an error code from the odometer. i have a obd2 scanner and it will not pick up any codes. my wife works with someone who had the engine on theirs changed who had the same problem. She paid the money to have it fixed.
Feb 5, 2008 at 11:29 AM
BMRFIXIT
  • 19,053 POSTS
we have a Snap On and it work just fine.
I use it more then any other scanner
You may have to visit the dealer for a reprogram.
Feb 5, 2008 at 12:08 PM
MATTI5475
  • 20 POSTS
[quote:0ac3a81c13="BMRFIXIT"]we have a snap on and it work just find
but you may have to visit the dealer for a reprogram[/quote:0ac3a81c13]
yeah they did not want to really help me, it was really busy at the shop he works at, so i d not think he could take the time. your not in New York are you?
Feb 5, 2008 at 12:30 PM
BMRFIXIT
  • 19,053 POSTS
I use it more then any other scanner.
yeah they did not want to really help me, it was really busy at the shop he works at, so i do not think he could take the time. your not in New York are you?
I know what you mean.
No sorry, far away from New York.
Feb 5, 2008 at 12:41 PM
MATTI5475
  • 20 POSTS
okay well thanks for all the information. i have a better understanding of what these cars are like these days.
Feb 5, 2008 at 12:53 PM
MATTI5475
  • 20 POSTS
I had Buick dealer scan and no codes came up. told me it be $310.00 for new cluster plus labor. so i told them to forget it. I cannot bleed and green to them anymore.
Feb 6, 2008 at 9:39 AM
BMRFIXIT
  • 19,053 POSTS
[quote:7b69ffa64b="matti5475"]had Buick dealer scan and no codes came up. told me 310 for new cluster plus labor. so i told them to forget it. can't bleed and green to them anymore.[/quote:7b69ffa64b]
You can Replace the cluster in less than an hour
I thought they going to say its an BCM module.
We had three done in the past month and a half.
(different brand)
Feb 6, 2008 at 9:53 AM
JTG433
Matt15475 are you still having this error code? I know its been years but, I'm dealing with the same issue and might have some useful information for you.
Jun 30, 2016 at 9:23 PM
THEDRESSDIVA
JTG433.... I also had my engine replaced, but also have had bcm issues. The odometer says error instead of mileage, and my security light is always on and radio locked. The dealership didn't know anything about it stating error for mileage as far as swapping engines, but it seems i need to replace the bcm. I tried a different bcm, but mine is a CX, not CXL, so as far as I understand, it has to be the same model and options for that to work without being programmed......
Sep 22, 2016 at 6:54 AM
THEDRESSDIVA
Also, something that has to be totally unrelated.... my rear lights don't work at night.... I changed out the entire assembly and still nothing...
Sep 22, 2016 at 6:57 AM
