1998 Mercury Villager Brake Lights
RONAD
I have a 98 mercury villager with 123,000 miles on it and it runs great however it has developed a break light problem that I am stumped on what is causing it. When I press the break pedal the third light above the liftgate is the only break light that comes on. I have checked the bulbs and fuses and those are all ok. I thought about replacing the break switch but since the third light comes on wouldn't that mean the switch is ok? I don't know what else I should do so please help me. Thank you
Ron
Jan 4, 2007 at 6:34 PM
BACKYARDMECHANIC
  • 337 POSTS
The third brake light does operate off of the same swicht so you are correct to think the switch is good. Check the things that the other two light have in common like a wiring harness or they may share the same ground.
Hope this helps
Jan 5, 2007 at 1:51 AM
RONAD
Just to let ya know I ended up replacing both brake lights. This fixed the problem, however I didn't buy the ¢.96 bulbs I went with the 3 dollar ones and hopefully they last longer than 6 months. Thanks for all of your help
Jan 25, 2007 at 9:55 AM
Suggested Repair
Replace both rear brake light bulbs; higher-quality bulbs may last longer. Because the high-mount lamp still works, the brake switch is likely good. If new bulbs do not fix it, check the shared wiring harness and ground for the two rear lamps.
Conversation Summary
A 1998 Mercury Villager owner reported that only the third brake light above the liftgate came on when the pedal was pressed. Bulbs and fuses had already been checked, and the owner wondered whether the brake switch was at fault. The expert said the high-mount lamp uses the same switch, so the switch was likely good, and advised checking a shared wiring harness or ground. The owner later reported that replacing both rear brake light bulbs fixed the problem.
